S2000 STR prep resource
... but seriously... my neck hurts.
Originally Posted by marks_lude' timestamp='1302016657' post='20431391
You can probably have 90% of a fully built STR s2000 for 50% of the cost. The essential basics really aren't that pricey and get you most of the way to a capable car. If you aren't chasing a national trophy, that last 10% probably won't make much of a difference.
Shocks are necessary. $2000 - $4500 mine were used Tein SRC's for $2k... then Springs for $200
Camber Joints are Necessary. $200(ish)
Performance Alignment. $75 - I've had a bunch of these...
Wheels are necessary. $685 - Cheapest version TR Motorsports
Tires are necessary. $600 - Hankook RS3's shipped from the Rack.
Performance Brake Pads $300 (ish)
Front Sway Bar is Necessary $400(ish)... mine was around $800 with my spherical bearing mounts.
Hondata / VAFC / NEO / TUNE $600(ish)
... obviously power mods like Header, intake, exhaust, etc.. raise the price.
Bottom line for a "prepared" car... $4560. That's with all the cheapest stuff. You change to Motons, Volks, Power Mods,...etc... it changes really quick. I'm into my car about $10k in mods.
You pay to play. Oh, and I love it!
I guess I also assumed if you are already an s2000 autocrosser, you likely have some shocks on hand, already have a front bar, etc from BS. I'm probably only into my build just over 2k.
$1200 for TSW wheels 255 RS3's
$25 to rent a fender roller
$400 for springs
$75 for helper springs
$??? valving for the koni's listed below (I have yet to do)
Carry over from BS:
$500 (i think) for used AS valved Konis
$350 for Gendron FSB
$50 for DIY shorty exhaust
$??? Hawk pads
Really only cost me under 2k to jump to STR from BS. If we find a way to reliably tune AP1s that will go up some.
I think a good basic STR build could be done for less than 3k, if you take my number, add it the Koni valving I need to do. I'd be willing to argue that small hp jumps from intake, headers, etc, are nice, but not necessary unless you are really focusing on tours or nats.
I suppose that it's all subjective... and therefore... I'm going to disagree.
You'd spend about that much to prepare a Civic for ST...and that's a $1500 car. I don't see those guys complaining about the prep costs.
Not anymore. Minimum buy-in for an ST Civic/CRX is at least $10k including purchase price of the car. Of course, everyone who is in ST at this point goes to Nationals and plans on winning. I don't think that expectation exists quite yet for STR. And none of them are DD'ers.
Early 89 Japanese Model that is 100lbs lighter than the Canadian 89 Si's = $$$$$$$$ if you can find one.
Motor = $2000
Shocks = $3000 minimum
ECU = $800
Header = $1500
Bushings = $200?
Wheels = $1500 unobtanium 9lb Volks or SSR's.
Rear Sway bar = $600
Seats = $600
Total = $10,200 + the car
STR will get there eventually. Well, we were there already and turned around and went home.
The ECU is definitely a must have for an AP2.
Motor = $2000
ECU = $800
Header = $1500
Bushings = $200?
Seats = $600
Hi guys, I just started doing some autox last Summer with my 07 AP2 --- COMPLETELY stock. I am NOT at the stage to do any serious prep as I am still working lots on my driving skills. Having said that, my original set of OEM tires (with ~33,000km = ~20,600 miles on them) should be swapped out now for something better for street and for STR. I am NOT prepared to change my wheels/rims though, so here is the quick question about tires options (specifically the front) on OEM wheels:
The Tire Rack search gave me 245/40 Front and 255/40 Rear; will the 245 actually fit on the 17x7 OEM front wheel?
The Spec tab / link says it needs 8" to 9.5" rim but I thought to just ask if anyone has actual experience. Thanks guys.
http://www.tirerack.com/tires/TireSe...ype=bestseller
Motor = $2000
ECU = $800
Header = $1500
Bushings = $200?
Seats = $600
Motor = $2000
ECU = $800
Header = $1500
Bushings = $200?
Seats = $600
For the large majority of us that would like to go to Nats "for the experience", and autocross mostly locally, we probably can't even drive well enough to justify paying twice the money for a tire that's .3s faster. There is probably a few dozen STR S2000 driver nationwide where it makes sense, and the rest of us have plenty of driver modding to do before we purchase that expensive last 10%.
This is the key for me... I am able to mod to my taste, and still be reasonably competitive at home, and have a car that (if I could drive) would not embarrass me at a national event. Meanwhile, unlike in stock, I can tune the car for autox, and it will perform almost the same on the street with no real changes.
My car just needs another seat and it will be a fully modded str car. I say fully modded and not prepped because the car needs a full season of dialing in. For me I look at buying str parts as my hobby and a long term investment.once the car is done I'll only have to buy tires and maintence each year. Autocrossing a s2k is a blast and it's very difficult to drive at the limit without nicking a cone. The thrill is like no other. Unless the tuning option changes the game for the ap1 and allows it to be more competitive I'll be looking for a blue cr in a couple years after I get out of school. I'll just buy a cr and transfer all my parts, then sell my ap1. Until then I need to work on the driver mod. I'm far off national champion winning. haha
Hell, I'm doing just about all this just to go to El Toro, Packwood, Lincoln Super Event, and the Colorado events this year... This is where this sport gets VERY expensive. Forget about the car build... it just hit me.
That being said... I still enjoy the hell out of it. I have a great co-driver... and we have a good time.
