S2000 STR prep resource
Old Sep 23, 2010 | 06:36 PM
  #2661
PedalFaster's Avatar
[QUOTE=Orthonormal,Sep 23 2010, 11:56 AM]Steve, I just noticed this...how come you have the AP2 going to 60MPH in 2nd gear?
Old Sep 23, 2010 | 08:45 PM
  #2662
Orthonormal's Avatar
So, short answer, you are assuming 275 rear tires?
Old Sep 23, 2010 | 10:09 PM
  #2663
PossumK's Avatar
Ah, I think I might see what you're getting at. Differences in the acceleration curve due to shorter/taller tires? In which case a fair comparison would be to have equal diameter tires on the AP1 and AP2?
Old Sep 24, 2010 | 02:45 AM
  #2664
bronxbomber252's Avatar
Forgive me if this is a repost
We already know that toyo makes a 245/35/17 R1R
we also already know that that gives a nice gearing boost to the AP1
however, we worry that the reduced treadwidth may be a disadvantage
I just poked around on the Hankook and Toyo websites and noticed the following
Hankook 255/40/17:
diameter: 25 in
Tread width: 9 in
Toyo 255/40/17:
Diameter: 25.2 in
Tread width: 9.4in
Toyo 245/35/17
Diameter: 23.8 in
Tread width: 9.2 in
So... the toyo 245/35 is wider than the Hankook 255 and only .2in narrower than the toyo 255... while giving a 5.1% gearing boost, enough to lower the AP1 top speed in 2nd gear from the 64-65mph range to 61mph... moving the powerband down like that could be a huge advantage and it looks like you are not giving up much of anything in the way of treadwidth
also, the 245/35 is measured on an 8.5 in rim, so in all likelyhood you are actually loosing less than .2in in treadwidth to the 255 and gaining more than .2 on the Hankook....
I think I may be trying the Toyo 245/35 next time around, even though I was originally planning on trying the Hankook next
Old Sep 24, 2010 | 04:04 AM
  #2665
alvanderp's Avatar
Tread width doesn't change with wheel width change, section width does. How flat that tread is to the ground is another matter.
John/Steve - I have DL1 datalogs that confirm 59.8mph on the limiter in 2nd on 275/40-17 A6's.
Old Sep 24, 2010 | 07:21 AM
  #2666
Forcednduckshn's Avatar
Originally Posted by PedalFaster,Sep 22 2010, 08:37 PM
Put this together while talking to my codriver about our switch from an SS Elise this year to a BS AP1 next year:
We're kind of depressed after looking at it; he's trying to convince me to buy a CR (or a Corvette ).
Thanks for posting! Guess my butt dyno was right.
Buy a CR if you can. They are awesome.
Old Sep 24, 2010 | 12:27 PM
  #2667
PossumK's Avatar
Hankook 255/40/17:
diameter: 25 in
Tread width: 9 in
Toyo 255/40/17:
Diameter: 25.2 in
Tread width: 9.4in
Toyo 245/35/17
Diameter: 23.8 in
Tread width: 9.2 in
Why is the Hankook 255/40-17 tread width so narrow? Even Hankook's new 245/40-17, on the website, is showing a 0.1 inch larger tread width than their 255/40-17. Is it possible they measured their 255/40-17 wrong? The 18" 255 is listed with a 9.5 inch tread width. Can this be easily measured by hand for confirmation?
Old Sep 24, 2010 | 01:37 PM
  #2668
robinson's Avatar
I'm certain that the kook is wider than my Star specs on a 9 in wide wheel.
Old Sep 24, 2010 | 02:53 PM
  #2669
sirbunz's Avatar
They seem bigger than 9" to me...
Edit ... Tires have 40psi in them so they are a bit curved. With the weight of the car pushing down on them, I'm sure the contact patch is at least from the points where I measured. I'm guessing at least 9.25" on the 9" rim. The angles make the ruler look off, but I double checked.
-Marc
Old Sep 24, 2010 | 03:22 PM
  #2670
CKit's Avatar
I think being able to raise the limiter in an AP2 is a significant advantage.
