S2000 STR prep resource
I have had similar experience where once at temp a quick water spray is all that is needed to keep the temperature from running away. This assumes two drivers and hot summer day here in Arizona. We spray the entire tread when it's that hot out (95F +). Infrared pyrometer is used. Lower air/pavement temperatures require less and below 70F tire insulators are desired to keep heat in them.
Originally Posted by josh7owens,Jan 9 2011, 03:58 PM
What I've learned about the kooks, if you get them over 135-40 they are slower then if they are in the 120-130 range. What works best for me is to get them up to 135-40 and spray just the outside edge of the tire with water, nothing else. It keeps the heat in the center of the tire cools down the outside edge to help with keeping maxium grip and not breaking away abruptly. If the outside edge of the kooks get to hot they wont hold in a high g situation as well. It's kind of like... grip, grip, grip, gone. Not much warming compared to a kook with alittle cooler outside edge. The big reason to have a co-driver is to quickly get them in the 120-130 range and keep them in that range. I went to events last year without a co-driver and had time that the tire wouldn't even reach 120-130.
Spraying the tires when >140deg does definitely bring the times down.
My temps are with a probe type in grid about 30-45sec after a run.
Originally Posted by ViperASR,Jan 10 2011, 01:37 PM
I weigh <150lbs. I'm priceless
I'm hoping to get down to <140 lbs by Nats, if I drive a car. If I drive my kart, I'm hoping to gain about 30 lbs just to make weight.
I had to wear 30 lbs of lead last year because my co-driver was heavier than I was.
