S2000 STR prep resource
Originally Posted by TheNick,Jan 25 2011, 01:13 PM
If you are referencing the Asura spherical bearing control arms, no they are not legal.
Not allowed any more metal than stock in any bushing except for the damper upper mount.
edit-
http://store.powerflexusa.com/honda-s2000-...shings-p75.aspx
only $444 but they don't have the #4 bushing. Does anyone make that one? could you use the asura on side the stock one as metal in it?
these are legal right?
I mentioned this a while back but I have some delrin bushings being made for my car. The guy making them is looking at bringing them to the market. I will certainly make everyone aware if this becomes a reality.
All the Delrin will do is cause binding if its in a dual-axis bushing. Leach has some great stories about Poly/Delrin - I've never seen someone get so animated over bushings
I made sure of this. There is a straight line through all the pivot points. This includes the front lower arm and the rear upper and lower arms. Should be able to replace everything with delrin with the exception of the rear lower arm bushing since that does need to pivot. I already bought the Mugen bushings for those. The only thing I am worried about would be having the front lower arm front bushing being delrin and the rear one being harder rubber and the effect that would have on the toe while cornering.
Originally Posted by pinkertonpunk,Jan 25 2011, 02:32 PM
I made sure of this. There is a straight line through all the pivot points. This includes the front lower arm and the rear upper and lower arms. Should be able to replace everything with delrin with the exception of the rear lower arm bushing since that does need to pivot. I already bought the Mugen bushings for those. The only thing I am worried about would be having the front lower arm front budging being delrin and the rear one being harder rubber and the effect that would have on the toe while cornering.
I need to find out people that would be interested in having some delrin bushings made. This would be the full suspension set for the car excluding the front rear most lower control arm bushing. This would work out to be 32 pieces since the bushings would need to be cut in half to install them. I am unsure of rules as far as posting in the R&C forum yet so I thought I would start here. This will probably cost less than most think but I still need some interest before he commits. Please PM me if interested and I can give you an idea of cost as well.
