S2000 STR prep resource
What are other STR S2000s weighing in at? I just weighed mine and it came in at 2677 lbs with 1/4 tank of gas... 2817 lbs with me in it.
The only weight reduction I've done is a 14.5 lb Odyssey battery and the typical B-stock exhaust modification. That's with stock sways, as well.
Sorry for the delayed pic mike, here is how I used the water heater blanket to insulate the K&N FIPK. It has seemed to be very effective so far. After a run the outside of the airbox will be warm but the inside is still nice and cold. I have also had none of the heat soak some people seem to mention with the intake and that is even with back to back autocross runs with downtime where the car is just sitting for 2 minutes until the next run.
My car weighs in at about 2650 with about 3/4 tank of gas. 2005 AP2.
*EDIT* Speaking of which... there really isn't much more I can do. I can replace my passenger seat, my stock air box, and get a high flow cat with a titanium exhaust... but other than that... I think I've done all one can possibly do as far as weight reduction goes. That's with the lightest wheels available (Buddy Club QF's)and one of the lightest coil-overs available (Tein SRC's).
I feel like I'm forgetting something though.... just can't put a finger on it.
I've done a Brail Battery 11.4lbs
Exhaust Cut-Off Mod
Removed Spare and Tools
Sparco Sprint and Sparco Bracket... (Probably weighs more than stock...)
Buddy Club QF's @ 14.4 lbs a piece
Tein SRC's (aluminum body... significant weight savings)
... heck... There has to be something else. I wish I'd weighed the stuff as I exchanged it / took it off.
Exhaust Cut-Off Mod
Exhaust Cut-Off Mod
Also, swaybar setup. I can't remember if you have no rear bar or not. I put the standard hollow Gendron front bar on which is so much lighter than that solid bar!
