S2000 STR prep resource
Old Nov 16, 2009 | 12:00 AM
  #531
PilotSH's Avatar
Originally Posted by TheNick,Nov 12 2009, 02:54 PM
Just because I want to try something else. The valving on them is very nice. I would tweak them a little here or there but I'm not sure if the actual construction/design allows what I want.
Penske's
Ouch, the class turns official and there are already 2 S2000s on Penskes... Why couldn't it be like ST and take years before people started migrating away from Konis...
Well, it looks like there will definitely be some cars/drivers to follow in the development of STR, although IMO, people are starting with the wrong cars
If I get back to the US next year, I think I'll buy a set of wheels to play in STR, but will limit any mods to those that are BS friendly or easily removable/undoable. Unless someone needs a co-driver to share expenses
James Yom
Old Nov 16, 2009 | 08:14 AM
  #532
angryfist's Avatar
Originally Posted by TheNick,Nov 12 2009, 03:54 PM
Penske's
What? No more Bilstein love?
Old Nov 16, 2009 | 08:24 AM
  #533
Orthonormal's Avatar
James: 3 at least on Penskes: Jim, Drew, and now Nick. I've thought about switching to STR just because having Penskes with threaded seats already would make adding springs so easy.
Old Nov 16, 2009 | 09:00 AM
  #534
TheNick's Avatar
I kind of got a deal I couldn't pass up. I really wanted to do the Bilstein thing though. I think you can get 99% of the shock for a 3rd of the price.
The biggest problem with all this is finding someone willing to do the valving the way I want to. Not the way THEY want to...doesn't really matter what the brand of shock is - finding a builder for them is the hard part.
Greddy Ti-C single went on yesterday - my goodness what a great sound. I wouldn't mind driving it 6+ hrs without the silencer. With it in - I bet you can't even tell there is an exhaust on the car.
Old Nov 16, 2009 | 09:16 AM
  #535
TheNick's Avatar
Originally Posted by ShocK,Nov 16 2009, 01:02 PM
After installing two sets of Koni Yellows I really can't stand them, I honestly don't see why anyone would spend the money on yellows and waste an entire day installing them (4-6hours cutting and drilling), plus coilovers feel much better to me and usually have more adjustability without springs rattling around (Ground Control).
Our STU classes were never all that competitive from what I can remember, STS reigned supreme with STX trailing behind closely. Can't say much for PAX, I was always concerned with RAW time IMO PAX was never that well setup for cars on street tires.
um wat?
I never cut or drilled anything and I can have the complete suspension off the car in less than an hour. Spring swaps take 1.5hrs and nothing rattles around.
The valving on the revalved Yellows is nearly spot on and you can run up to 1000lb springs and the car is still extremely streetable. In fact - I took my car for a couple hour trip yesterday.
Old Nov 16, 2009 | 10:28 AM
  #536
angryfist's Avatar
Little bit easier for me. Shouldnt be a problem to rebuild and change the shim stacks after initial valving. Mine are getting built up right now.
Whats the weight on the Ti-C?
Old Nov 16, 2009 | 10:33 AM
  #537
TheNick's Avatar
Listed weight is 23lbs. Rear section comes off pretty easily to drop 7-8lbs I guess. Doesn't seem nearly that heavy when you have it in your hands.
Old Nov 16, 2009 | 11:05 AM
  #538
IMP's Avatar
IMP
*grumble* *grumble* *grumble*
--kC
Old Nov 16, 2009 | 11:59 AM
  #539
Random1's Avatar
Originally Posted by TheNick,Nov 16 2009, 11:16 AM
um wat?
If installing with the stock top hats, dust boots, and bump stops then you do have to drill for the larger Koni shaft. I don't know what has to be cut.
Once the initial instalation is done then the Yellows take the same time as any other.
Old Nov 16, 2009 | 12:00 PM
  #540
TheNick's Avatar
So it takes longer than 5min to put a bit in a drill and run it through the stock top hat?
I did it so long ago that I don't remember a thing about it.
