S2000 STR prep resource
Originally Posted by TheNick,Dec 3 2009, 10:26 AM
I get $445 not counting the compliance bushing (which isn't available anymore).
Items 1,2,10,11,12,14
Originally Posted by PilotSH,Dec 3 2009, 05:14 PM
Did they ever make the compliance bushing or they just never got around to doing it? Odd that they list the part on the site, but don't make just that one bushing anymore...
I'm running a K+N but I'm doing so on a whim. It looks to be alright and it weighs less so... I'm thinking about wrapping the tube in some sore of reflective material just to combat heat but... I don't have any dyno proof.
What's funny is the main reason I'm running it is so that I can make room to mount the remote reservoirs on the cross beam.
Originally Posted by daverx7,Nov 30 2009, 09:11 PM
Thanks for the confirmation!!
I got a very swift response from TC Kline regarding if they have collars and recommended spring rates for their S2000 struts. So, I thought I would share.
Looks like I can do a pretty good rate without touching them... but, should probably consider custom valving to allow for more when they are ready for a rebuild.
BTW, their collars are ~100 bones per wheel. How is that price compared to other sources? Any recommendations on that? Is there anything I should consider in getting a set of these, or are they pretty much the same.
Thx!
-D
Originally Posted by TC Kiline
We do have threaded collars that can slide over the struts so you can adjust ride height on the Honda S2000. Does STR allow such modification?
Unfortunately we do not have any proven recommendations for spring rates for your car. As far as acceptable ranges...the struts can handle between 300 # springs all the way to 700 # springs.
Thx!
-D
Dave there was a set of comptechs for sale in the classifieds. $100/wheel with springs would be a good price
If you run 255's X 4 I would run 700# springs. But I have no idea if that would be good with OEM shock valving.
Originally Posted by PilotSH,Dec 4 2009, 03:59 AM
So you have the K&N FIPK? The one with the shrouded filter compartment? Did you by any chance weigh it? I'm curious about the weight, but my searches have not yet found a definitive answer.
I took it for a long drive at one point and quickly opened up the hood when I got home and everything was still ice cold. I imagine if you sit in stop and go traffic it would be different though.
