Drivers window wont go down all the way when lowering top
Originally posted by Stratocaster
My S (MY02) has had this fixed 3 times so far. The TSB covers all model years. Take it to the dealer and show them it. the TSB was updated in April 03 and the part were updated (again). Only time will tell if this new updated part lasts longer then the other 3. From what I understand, the problem is that water gets on the internal electric parts and causes them to fail.
my02 statred having the same problems, just after a couple thousand miles.. i read up on it here and someone suggested you put the window all the way down and then all the way up again using the auto button to go down .. 3 times in a row.. and it would solve it.. well i didn't believe at first.. but i did it and it's been a year now, and nothing since..
so give it a try maybe it'll fix some odd thing..
i was told it was a memory position for the window.. and it restores it or something.. but whatever it was it worked for me..
"Use the search, Luke"
https://www.s2ki.com/forums/showthread.php?...threadid=131795
https://www.s2ki.com/forums/showthread.php?...?threadid=71899
https://www.s2ki.com/forums/showthread.php?...?threadid=67990
https://www.s2ki.com/forums/showthread.php?...?threadid=90073
https://www.s2ki.com/forums/showthread.php?...?threadid=91226
https://www.s2ki.com/forums/showthread.php?...?threadid=75435
https://www.s2ki.com/forums/showthread.php?...?threadid=70371
https://www.s2ki.com/forums/showthread.php?...?threadid=38297
https://www.s2ki.com/forums/showthread.php?...?threadid=19289
I could go on and on and on and on and on.........
[QUOTE]Originally posted by THE4TH
[B]my02 statred having the same problems, just after a couple thousand miles.. i read up on it here and someone suggested you put the window all the way down and then all the way up again using the auto button to go down .. 3 times in a row.. and it would solve it.. well i didn't believe at first.. but i did it and it's been a year now, and nothing since..
Someone post the fix in this thread so it will be at least posted in there as well.
Mine just did this, and I tried the fix and it lasted a day. I'm not sure if I did it right. I put the window down, then presses the down button and held it until I heard a click, about 10 sec. Then I put it up, then pressed the up button again until I heard a click, about 10 sec.
So what are you going to do? From what it sounds, even the TSB's don't fully fix it. I'm sure there is somone on here that has pulled their door apart themselves and cleaned the contact off that is getting corroded. If that's what is causing it, then I might try it.
Anyone have a copy of the TSB that says what is causing this to malfunction which requires a new part to be added?
i think i will just leave it. i dont mind it all that much. sometimes when i put the top down i want the side windows up anyway. this just saves me the time of putting them all the way back up
