S2000 STR prep resource
Originally Posted by captain_pants,Jun 24 2010, 11:30 AM
Definitely, I have pictures of my car 3-wheeling over crests when in Stock trim. I do have my shocks droop-limited so they're 1" shorter than stock when fully extended.
Your swaybar is limiting droop travel when you see it 3-wheeling, not the shock.
Originally Posted by steguis,Jun 24 2010, 10:28 AM
I just got a S2k a month and a half ago (upgraded from a RSX Type-S) and autocrossed it twice so I can't really contribute much to this thread but just wanted to thank everyone for sharing their information. On that note, I just wanted to share that I'm running 17x8.5 OZ Allegeritas +63 offset with 255/40/17 star specs all around with maxed out front camber and rolled fenders and I have no rub anywhere.
I am a reformed Type S driver and now addicted to the S2k.
Originally Posted by captain_pants,Jun 23 2010, 07:59 AM
I have definite and very hard A-arm rubbing at full droop with the 949 wheels: https://www.s2ki.com/forums/index.php?showt...post&p=18989366
Anyone can check this by jacking up the front end and turning the wheels to lock either direction. Luckily this situation shouldn't happen very often but the possibility is there to screw up the wheels pretty bad if it does.
Originally Posted by piston_honda,Jun 24 2010, 05:24 PM
Are you also on clubrsx.com?
Originally Posted by Random1,Jun 24 2010, 09:04 PM
Are you sure you did not buy 17x10+52?!
I fully understand your point about full droop. Ok guys, a little thought exercise here: Lets say you're cornering hard in a steady state, the front swaybar is limiting body roll and has effectively unweighted the inside front tire. Everyone would agree that the inside front shock is more extended than the outside front shock, right? Now the car goes over a crest. What happens? As both front tires drop a bit, the inside shock doesn't have to extend too much more to see full extension. The outside shock doesn't necessarily have to fully extend for the inside one to top out.
I work in the heavy-duty transit field; I've had this exact phenomenon happen with our suspensions and cause some undesirable side-effects. Granted, an STR S2000 has just a little (
) less roll/G-load than a transit bus, but we also have dramatically less suspension travel too.What I really need to do is get off my butt and make bracketry to mount those shock position sensors I got over a year ago. Right now everyone (including me) is going off of gut feel without any data.
Originally Posted by TheNick,Jun 23 2010, 06:23 AM
Typical if people aren't running enough spring rate or are too low. You can do the same thing on the stock wheels and tires.
