S2000 STR prep resource
Old Jun 28, 2010 | 12:30 PM
  #2141
ComposiMo's Avatar
Originally Posted by Random1,Jun 25 2010, 10:42 AM
in a very high speed sweeper with high loading, not at lock, and not an S2000.
S2k's can do it....
Old Jun 28, 2010 | 12:45 PM
  #2142
daverx7's Avatar
Originally Posted by ComposiMo,Jun 28 2010, 04:30 PM
S2k's can do it....
I agree! I've packed the front wheel before on my AS prepped car. Just like John, I have a pic to prove it as well.
Old Jun 28, 2010 | 12:49 PM
  #2143
imstimpy's Avatar
Originally Posted by TheNick,Jun 28 2010, 10:11 AM
More pressure. Should be up near 40lbs - especially with that little camber and roll stiffness up front.
You need heat. Don't spray them unless they go over 130-140deg.
If there are more than 50runs on Jason's tires then he's probably losing about a full second off fresh Toyos.
I'll preface this by saying we kept things simple to get a feel for the chassis. That meant tire pressures and shock adjustments were kept to a minimum.
With that said, I'll be trying higher pressures next time. It makes sense that the carcass could be distorting and causing the beveling. Are the Hankooks showing evidence that they are pressure sensitive?
Without our pyro we had no idea what temps were. The tires never felt tacky, like a Yokohama or Dunlop, but they also took forever to show signs of falling off too. On our STU Subaru, we would have started spraying the tires after two runs. Arguably incomparable cars though.
Getting 50 runs out of a street tire is just silly. He is probably way beyond that. Just this weekend his tires saw 20 runs.
Old Jun 28, 2010 | 12:55 PM
  #2144
BrianGT's Avatar
I am on my 2nd set of Hankooks on my civic, and found that they seem to be quite pressure sensitive. We set them to the regular pressure for the first run, and they were good. They were 2 psi higher after the first run, so we left them there for the second, bleeding them to the +2 psi value, and ran them for the next couple runs. On the 6th run, we dropped them back to the regular pressures, and gained a good bit of grip for the last runs.
32F 36R vs 34F 37R for a 225 on a 7.5" wheel
Seem to be the same way on my wife's s2000
Old Jun 28, 2010 | 01:08 PM
  #2145
alvanderp's Avatar
Originally Posted by ComposiMo,Jun 28 2010, 12:30 PM
S2k's can do it....
Yea - but you aren't near full lock there, nor are you close to the shock fully extending. I don't think anyone is debating that given the right circumstances you can lift an inside front wheel with an S2k. What is at debate is that it would/could happen at full lock at full shock droop.
Old Jun 28, 2010 | 02:51 PM
  #2146
Orthonormal's Avatar
Originally Posted by imstimpy,Jun 25 2010, 12:15 PM
It sounds like number 14 is the source of "shock knock" for those of us reusing stock mounts? It is caused by insufficient bushing compression that allows the sleeve to knock against the washers surrounding the bushing.
Either increase the shock nut torque, thread the shock shaft deeper, or simply remove number 14.
Once upon a time, I thought it might be that sleeve either moving up and down against the bushing washers, or rattling sideways against the shock shaft. I made sure that the nut was tightened to fully compress the bushing washers against the sleeve I also tried wrapping the shaft with electrical tape to take up any slop between the sleeve and the shaft. Neither attempt reduced or eliminated the rattle.
Old Jun 28, 2010 | 04:37 PM
  #2147
captain_pants's Avatar
Any thoughts on whether the J's S1 camber kit is legal for STR? It's not part of the control arm, it's effectively part of the hub.
SCCA rules for reference:
(14.8.I.1)
On double/unequal arm (e.g. wishbone, multi-link) suspensions,
only the upper arms OR lower arms may be modified or replaced,
but not both. Non-integral longitudinal arms that primarily control
fore/aft wheel movement (e.g. trailing arm(s) or link(s) of a multilink
suspension) may not be replaced, changed, or modified.
Old Jun 28, 2010 | 04:49 PM
  #2148
chetly's Avatar
I dont see where those would be any different than replacing the upper ball joint with specialty products ball joint #67220 except your paying more than $100 more. Guy Ankeny also offers upper control arm bushings that give you about -3.5 degree's of camber.
Anyone know what the advantages are or any of these? I can get the Specialty Products stuff through for $60 each which is way cheaper than either of the other options...
Old Jun 28, 2010 | 07:31 PM
  #2149
josh7owens's Avatar
130-140 on rs-3's? thats hot hot
Old Jun 28, 2010 | 07:47 PM
  #2150
daverx7's Avatar
That does seem a bit warm, but the kook z214's seemed to like more heat than the v710's and a6's. Maybe Kook designs them that way.
