S2000 STR prep resource
Old Oct 10, 2010 | 11:36 PM
  #2801
LickyMYwalker's Avatar
[media]http://www.youtube.com/watch?v=nhLDjEW_LM0 [/media]
my autox from today.
setup is Tein SRC coilovers 16kg standard all around
alignment:
-1.6 F -2.4 R
0 toe all around
225/255 starspecs on wear indicators
stock sways (rear is attached)
first time ever on this setup and it was a blast! ill dial in some rear toe later.
Old Oct 11, 2010 | 07:14 AM
  #2802
imstimpy's Avatar
Originally Posted by misterwaterfallin,Oct 10 2010, 05:34 PM
in the rear. Im 255's on stock ap2 8.5's and have quite a gap between the outside of the tire and the lip of the fender. that is with only a roll
my thinking is that is might help with some of the over steer problems
What oversteer problems?
I might also add that all the cars I've worked with so far decreased snap oversteer by widening the front track, not the rear.
Old Oct 11, 2010 | 07:52 AM
  #2803
josh7owens's Avatar
Me drilling 2 3/4 inch holes in my trunk to run the quick releases through isn't illegal is it? in a way It's modifying the chassis but isn't that what everyone does?
Old Oct 11, 2010 | 08:02 AM
  #2804
pinkertonpunk's Avatar
That is my plan. I was told you can drill holes to run the hoses. It doesn't say how large so I has told that would be fine.
Old Oct 11, 2010 | 08:21 AM
  #2805
GEARHEAD's Avatar
[QUOTE=ALFYonso,Oct 10 2010, 10:44 PM]I've got a question for you guys too - how are you guys addressing rubbing on the inner-body up front?
Old Oct 11, 2010 | 05:31 PM
  #2806
PedalFaster's Avatar
No isn't.
Originally Posted by 13.1 AUTHORIZED MODIFICATIONS
The addition of small holes for attachment hardware for authorized modifications is implicit (e.g., holes for fasteners to mount additional gauges, holes for brackets to mount shock absorber remote reservoirs, etc.). However, these holes may serve no other purpose.
FYI, the Solo rule book is available for free download at http://www.scca.com/documents/Solo_Rules/2..._solo_rules.pdf.
Old Oct 12, 2010 | 11:11 AM
  #2807
RavynX's Avatar
Originally Posted by chetly,Oct 7 2010, 09:22 AM
Has anyone seen this video? There is the STR love in there. 2 different spots.
I'm at 0:45 (42 STR). This was my first Nationals event. Sweet vid and just as good as last year's. I need suspension soooo badly. I'm still on stock suspension with nearly 50k miles. Reading through all of these STR threads looking for suggestions.
Old Oct 13, 2010 | 10:39 AM
  #2808
chetly's Avatar
Just in case anyone was interested, i measured the spring rate of the saner bar last night.
softest setting: 554lbs
medium setting: 667lbs
hard setting: 798lbs
Old Oct 13, 2010 | 10:52 AM
  #2809
josh7owens's Avatar
How safe is this?
Would there be any gains to be had over the K&N filter?
Ps- RavynX I'm lovin that dark blue s2k! Might be my next color
Old Oct 13, 2010 | 11:25 AM
  #2810
fsmtnbiker's Avatar
Originally Posted by josh7owens,Oct 13 2010, 10:52 AM
How safe is this?
I personally wouldn't ever run my car like that. All it takes is one spin kicking up a bunch of dirt and dust and you've got potential problems like scratched cylinder walls.
I would estimate approximately 0.0000382 hp loss over a clean filter of any kind. The screen presents more of a restriction than a filter would because of the size of the media.
