S2000 STR prep resource
If someone else can do the tests to prove otherwise then great, but at the moment I am going to stick with 255s.
Plus on the information I have seen, the 245 RS3 is still just as wide as the 255 so I don't know if the sidewall would really be that much better.
just wanted to note, any one interested in the ball bearing bar mounts needs to be prepared to grind the crap out of thier bar. I tried the "light sanding" bull crap and then tried hammering them on and it wasn't happening! I spent 4 hours tonight trying to get this bar togeather. I had to beat the crap out of it to get the bearing back off then broke out the grinder and went to town. Then got it all back togeather. O also you can't re-use all of your swaybar bolts either, why you ask? Because he welds the side so close to the hole that you cant get the bolt in. I had to grind down the "built in washer" and then was able to put in the bolt. For $285 you would think they wouldn't require so much work and atleast include the 4 bolts you need. It would cost him a extra $1.25 at most.
-rant!
-rant!
-rant!
-rant!
I'm still running the 255 Star Specs on my S2000. I'll continue to use them until the temperature gets up to 80+ and sunny, then I'll put the Hankooks back on and abuse their wider slip-angles.
As others have said, my Gendron bar and bearings went together perfectly. I purchased both almost a year ago.
ok thanks, I've read/looked at the fastracks a couple times but 99% of the time it doesn't seem to pretain to us.
They are my tire of choice in STU, due to their stiffness on turn-in and their corner-exit grip. Going to a softer sidewall, like the RE-11, required early turn-in and more slip angle in the sweepers- quite a different driving style.
As much as I hated trying to install these ball bearing mounts, I wanted to reply back on my input since they have been on the car. I'm in love! before on the standard bushing I would rub the inside fender with my snow tire in a tight/compressed shock travel turn. Now it doesn't rub at all. It feels more firm and theirs no lag at all in a transition. Plus its set at one notch softer then perviously. So this is amazing! A better feel while using "less bar." I'm very happy with the feel of the car with these ball bearing mounts.
