* * * FAQ's, DIYs, and Maintenance! * * *
Old 12-06-2007, 09:05 PM
NVMY4N's Avatar
Thumbs down * * * FAQ's, DIYs, and Maintenance! * * *
Read a helpful thread, DIY or, How-To that's not located here? PM an Under The Hood Moderator with Helpful Threads to be added to the Archive
---FAQ's---
__________________________________________________ _________________
Other Helpful FAQ's
** Key Torque and Volume Specs - by Bob A (SD) **
S2000 Fact List by Model Year
---UTH Changes on the MY06, Differences from MY00-MY05---
CLICK HERE
ENGINE STUFF:__________________________________________________ __________________
INTAKE STUFF:__________________________________________________ ___
EXHAUST STUFF:__________________________________________________ __________________
CLUTCH AND TRANSMISSION STUFF:__________________________________________________ __________________
SUSPENSION AND BRAKE STUFF:__________________________________________________ __________________
ELECTRICAL AND ELECTRONIC STUFF:__________________________________________________ __________________
BODY STUFF:__________________________________________________ __________________
FORCED INDUCTION (S/C & TURBO) STUFF:__________________________________________________ __________________
REAR DIFFERENTIAL AND FINAL DRIVE STUFF:__________________________________________________ __________________
INTERIOR STUFF:__________________________________________________ __________________
DEALER STUFF:__________________________________________________ __________________
Winter Storage:
The following users liked this post:
MartyRay (05-04-2021)
Old 11-30-2010, 08:28 PM
ans2k's Avatar
HID lighting info website takes me to a different website.
Old 12-20-2010, 08:16 PM
wrecked's Avatar
any info on soft top de-burring?
Old 06-05-2011, 10:29 AM
robrob's Avatar
Here's a list of my How-To's
Build an S2000 Race Car
S2000 Valve Adjustment
DIY Alignment
Replace S2000 Wheel Bearing
Compression & Leak Down Tests
Install SPC Adjustable Camber Ball Joints
Install Brake Ducts
Install APR GTC-200 Wing
Swap the Differential
Install Racing Harnesses by Matt
Install a Fire Suppression System by Matt
Remove Air Conditioning
Racing Exhaust
Oil Catch Can
Install Roll Center Adjusters
Install Front Bump Steer Kit
Remove Catalytic Converter
Pedal Mod for Heel&Toe
Corner Balance
Replace Suspension Bushings
Replace the Radiator
Install an Oil Cooler
S2000 Aerodynamics
Old 07-06-2012, 03:37 AM
dodgydave_uk's Avatar
Serpentine Belt:
http://dave.harris.net/s2000-replaci...uxiliary-belt/
Rear Drop Links:
http://dave.harris.net/s2000-changing-rear-drop-links/
Rear Brake Pads:
http://dave.harris.net/replacing-s2000-rear-brake-pads/
Old 07-11-2012, 11:02 PM
hackiroku999's Avatar
Any dyi threads on replacing transmission mounts?
Old 01-07-2013, 04:32 PM
kjoons's Avatar
+1 on roku's inquiry.
Old 01-23-2013, 09:57 PM
jdms2000f20c's Avatar
Replacing the transmission mount is actually really easy. You remove a total of 7 bolts the 3 on the end that bolts it to the chassis and then 4 bolts that bolt the mount to the tranny and it comes right out. I replaced mine the other day with the innovative mounts
Old 02-16-2013, 05:08 PM
Chris Allen's Avatar
found this and thought it should be added to the list (bumper tab relocating)
https://www.s2ki.com/s2000/topic/837...tab-relocated/
Old 04-14-2013, 06:24 PM
sayaingokou311's Avatar
does anyone have a breakdown of how to replace your carpet? Im trying to replace mine but run into a couple road blocks. Thanks
Quick Reply: * * * FAQ's, DIYs, and Maintenance! * * *
